Hello,
I have a Anenji 12k 48v 120/240 split-phase inverter, I had two Humsienk 48 v rack batteries and the system ran great, decided to add another Humsienk battery and the inverter alarmed out. I've tested each battery alone connected to the inverter and the inverter gives an BattOverCurrHw alarm. With the batteries disconected from the inverter work fine all three say 100 soc, both charge and discharge buttons are on, then when I connect a battery the discharge button on the app shuts off and eventually the charge button on the app shuts off and the battery alarms out. I have the dip switches set accordingly via what the manual says. Like I said it started when the third battery was connected. Also shoudl the soc led's show the battery soc on all three batteries? when the batteries are connected together the soc status light on battery 2 and 3 are off and they are only working on the first battery in the chain. I am new to this and appreciate any help I can get.
I aslo made sure the RS485 cables are good.
